Advance Auto Parts can get the small buick oddfire V6 dist.for 60.00 complete, then if you are running batchfire all you would need to do is remove the points and tack weld the advance locked,if you using seq. it would need a single trigger reluctor and a pick-up installed. IHO I would use the oddfire dist because the rotor has a trailing end thats about 25 degs. long,it can be set at the end of the trailing end at #1 cap pole and still be phased right at 24 to 27 degs. advance. I am using a Mallory Unilite opticle trigger and made a new trigger shutter wheel with one window instead of trying to plastic weld seven windows shut on a V8 shutter wheel. If any one needs help with theres , get in touch with me, I use to mod racing dist. , build crank trigger wheels, and pick-up brackets for Nutek Firepower ignitions, they made the first computerized DIS ignition, that had selectable advance curves and over- revs on the fly,they also made one that used a crank trigger and a locked dist., I have one of the dist. models. Nutek provided Buddy Ingersol with the locked dist, crank trigger unit that he ran on his Pro-Stock Buick stage 2 car, Nutek supplied alot of racers with their ignitions in the 80"s,. Chip Gennassie finished eigth place at the Indy 500 in 1983 in a back-up car running a Firepower DIS. jeff
