Look Quick said:1/8" up and down and in and out a lot is not a good sign.
Ditto
Still think rings not seating is your main hurdle.
Good advice! & sometimes you have to look real close inside the exaust houseing.Behind the turbine blades & if there is any sign of oil at all it will smoke.need boost said:Just sent you a private message back, I went thur this myself. My uppipe was clean as well as the trottle body but it was my turbo!! It was a fine mist I quess and it didn't settle on the uppipe and such, the was none or extremely little in the intercooler. I took her down the road and hammered her untill she was blowing out a ton of smoke and shut it off at my shop real fast, pulled the pipe off between the turbo and the intercooler and there was the oil!! Got the turbo rebuillt and she has run great since. If you whipped out a cam in it you can almost bet money that the metal got your turbo seals and its leaking somewhere now. Daniel Ray
took dp and innercooler off no oil let run with dp off and no oil. throttle body no oil. did notice my fuel pressure will not hold. brand new injectors. help fp for 4 days before breaking motor in now 1 hr. also do you think injector wire bad? took okk and noticed on plug corroded on bottomRed Regal T said:Sounds like the turbo to me. Can you try another known good turbo? Easier than anything your contemplating. If you feel you did everything right on the re-build, it probably's good. Try the turbo first. Common cause of mystery smoke.![]()
just took out my plugs and they are all black and did a compression test and gotRed Regal T said:I just a stock turbo off my GN. Car smoked on startup and smoked after idling for five minutes. No smoke during driving. I can't say for sure if there was oil in the inlet, but replaced teh turbo, and no smoke. Also, this wasn't the first time I changed a turbo and it fixed a huffing problem. Just my best guess at your problem. Changing turbo always worked for me.![]()
thanks bud guess i got to call the machine shop and take the huge weight off there shoulders. so should i leave the innercooler off and unplug the maf and pour top engine cleaner down the pipe?Intercooler said:Absolutely! A little oil mist put into the charge-air will for sure make a smoke cloud!
