So did you ever try the things I talked about? Have you listened to each injector to hear if each one is pulsing evenly with a hose? I personally think the rings arent breaking in from all the oil supplements you threw in there during break in. You need friction for break in, and unfortunately, it didnt have enough. I would say that you either have 1 of 2 things (if each injector is firing fine).
#1. Wiped guides.
#2. Rings wont break in.
#1- you cant do a whole lot for this other than pull the heads off and make them throw in new iron guides with the proper clearance, and dont use those teflon seals next time. Use Fel-pro style ones.
#2- You can do the things I mentioned, and just give it time....The light weight oil and WOT runs. Spraying alot of alky can help wash the slippery stuff off the walls and rings as well. There is an old school method of breaking in rings that refuse to break in, but I personally wouldnt do it on my car....they used to sprinkle Bon-Ami into the carb while revving it up. After that, they would change the oil immediately, and change it like 3 times. But like I said, I wouldnt do it.
Have you done the leakdown test yet? You're banging your head against the wall, but it seems like you're doing everything but what you should be doing to fix it. Just get out there and do this:
Listen to the injectors.
If they're fine, do a leakdown test. If leakdown is bad, do the things I mentioned to help break the rings/walls in.
