jpwalt1987
- Nov 9, 2003
....what do you think it will run post!! If figured why not ask opinions.
Here is the combo:
109 block .030 over with rjc girdle
diamond pistons
total seal rings
K-1 stock length rods
Eagle 3.4stroke crank
BHJ balancer and JW flywheel
224/224 billet solid roller/ .560/.560lift
GN-1 heads ported by Todd McKenzie
249cfm intake/ 219cfm exhaust
Stock intake manifold ported by same above
1.60 T&D roller rockers
Th400 trans with ATI brake
ATI 10" convertor 3800 stall
3.42 gears and moser axles
PT-70 .63 a/r 3in inlet
Precision FM
BGC headers with Tial 44mm gate
Custom built 3 1/2 dp and exhaust
-10 fuel line with aeromotive a1000 pump and accufab reg in sumped tank
MT ET streets 28x11.5x15
Thats about all i can think off right now. what do you think it will run? anything you would change and why? thanks, jeremy walters
Here is the combo:
diamond pistons
total seal rings
Precision FM
