So what will happen with Bison's car tomorrow?
What will happen?
  • Car will run bottom 10's and drive on the trailer
    Votes: 25 33.8%
  • Car won't even make a full pass and explode
    Votes: 10 13.5%
  • Car will make a 9 sec pass because we get greedy and turn up the boost past 25
    Votes: 35 47.3%
  • Car wont even make a full pass casue of issues
    Votes: 4 5.4%
  • Total voters
    74
I voted the car won't make a full pass because of issues.
I don't think the starter will allow you to make a pass with empty pizza boxes on the trunk.
You have the 9.9 with just a normal 60ft.
I hope the weather holds out.
10.13 @ 133.4 over reved 2cd gear, 1.48 60
He messed and got no data
How'd he over rev 2nd?does he have a manual valve body?
1.48 60'!!! I need 29x9 slicks
No,2004 r with stageright. He didn't have the car in 3rd for the auto shift. he saw 6600 on the tach.One cylinder sounds a little light on compression. Taking it home to check It out.
:0 oh no!!! Sounds wayyyyyyyy to familiar!!! Please keep us updated. Are you going to look at it tonight or tomorrow?
I hope this motor did not piss off Brian, "they wouldn't like me when I'm angry"!
I was about to flog it again but realized it probably wouldn't make it down so I opted to leave. #5 low. I'll tear it down Friday hopefully. We had a problem with the injector harness on #5 when trying to diagnose the low cyl at the track. The power wire easily separated from the connector. Didn't melt anything so it shouldn't be too hard to fix. Wish I waited later to run the air quality improved a lot after darkness. Early it was very humid.
That is not a good 60'. I was trying to dial in the two step. The first pass it spun the second it looked like it dropped too much rpm when it left. Should 60' 1.40-1.42 the way it was launched.
BRIAN CHECKING THINGS OUT BEFORE RUN #1
BRIAN / OTTO / GNBRETT
OTTO TELLING BRIAN TO STOP TEXTING AND GET OUT THERE AND RUN IT !!!!
I HAVE VIDEO BUT IM NOT SURE HOW TO UPLOAD IT
email it to me and I will put it on my web page
Bob
(anxiously waiting on the engine diagnosis)
so what do i and the other 19 win? j/k hope everything is well in the motor.
#5 has only 60#s of compression. When diagnosing it at the track one of the injector wires for #5 fell out of the connector.Not sure this may or may not have helped it along. We feel the over rev of second most likely was the issue.All 6 plugs looked perfect.
Just turn it up or add nitrous. That usually helps those weak cylinders ;)
Aaaa, who needs compression. Just need a little more boost to compensate.
My bet's on a cracked ring.
Keep us posted. :biggrin:
