Just run my car at the local track today with my new combo. To say the least I am totally impressed. The car ran flawlessly and pulled harder than I ever thought it could.
Even better I get lined up next to a '03 Cobra. Smoked him. I told my buddy I was shooting for mph not et to tune the car. He asked me what I thought it would run and I said probably low 12's. Well my first run was awesome 11.39 @ 118 mph.
Maybe after a little more tuning and boost I could hit the 10's. That would be great!!!!
My motor is stock with the exception of a bigger flat tappet cam, stock heads, bored .030 over, and a TE60 and Precision Stock Location I/C and of course a 3" downpipe.
This run was perfect 0 degrees KR 1.62 60' and I was running 23 psi boost. My stock combo before was 12.40's @ 108 mph. I just cannot believe just adding a turbo and intercooler and downpipe would make this big of difference.
I think I could use some bigger injectors because I tried turning up the fuel press. but it made the car run leaner!!!
I tried to take a digital pic. of the timeslip but its too light on ink. Here's the run.
R/T .227
60' 1.626
330 4.669
1/8 7.254
MPH 95.06
1000 9.493
1/4 11.391
MPH 118.11
5psi launch
Open dump pipe
14 psi in slicks 28x9.0-15
Fuel Press. 46psi line off, turned it up more and went slower.
Reds 107 race chip at 23psi
0* KR 02#'s 750's
8psi in drivers side air bag, 15psi in pass. side air bag.
Pinion Snubber
Burning 116 octane Sunoco Maximal Red
If I could get a better 60' I'm sure I could go a little faster. My suspension is bone stock with the exception of the air bags and a pinion snubber.
Im having a few beers tonite to celebrate.. This is awesome. I drove the car 70 miles each way, bolted the slicks on and run it. Then drive home getting 25 mpg.
I made 4 passes each was 11.50 and quicker and then I get approached by the tech guy and he asks where the roll cage is. I said well with a cage its hard to put groceries in the back seat. :biggrin: He didn't like. He said one more pass quicker than 11.50 your gonna have to call it a day. So I put Reds 93 chip in lowered the boost to 19psi and I still run a 11.60 @ 115mph.
Just wondering how fast can you go with an XP pump thats hotwired. Starting to wonder if I need to go with a double pumper set up or bigger injectors. What do you guys and gals think????
R/T .227
60' 1.626
330 4.669
1/8 7.254
MPH 95.06
1000 9.493
1/4 11.391
MPH 118.11
5psi launch
Open dump pipe
0* KR 02#'s 750's
Pinion Snubber
