- Nov 30, 2009
You can have 14 v on 24 gauge wire but it won't allow much current. Hot wiring uses larger wire to pass more current . It's good you have 14 v , now upsize the wire .
SignUp Now!You won't be disappointed in TR6 I love mine using LS coils, the 2step works great, diagnostic mode has saved me time diagnosing problems, setting the cam sensor perfectly I thought I had it right double checked with the TR6 I guess my mark on the balancer was out there is a large window they will run with you can tweak it to advance or retard to injector timing. After ALKY this is my second favorite mod and I don't have to worry about the old glitchy module.
Did you order the wires with the TR6 ? Because the coil ends are different than the stock buick.I agree also on the wires, yesterday I ordered a tr6. So new wires and coil ( ac delco) I don't want any issues in the future. So hoping for a good update next week.
The v6 truck wires fit well with the TR6 and the 3.8.
Kirbans has a set of wires for the TR6 CHEAP !! I use them on my car and they work very well. Went 6.67@ 107 mph in the eighth in Bowling Green last year at only 24.9 psi
Bryan
I just say it sucks if you spendt $6-700 "IF" it was just a wire issue.
Guys you can save a few bucks by ordering the coil pack and wires with GM part numbers.
Coil pack is AC Delco D599A
Plug wires are AC Delco 746SS
