I saw this on the Corral:
"One of the most difficult parts is trying to predict your VE at different RPM and boost points. One thing that really helps, mostly for street tuning, is the letter "L" key on your laptop. You can drive all around and have someone hold down the "L" key and the computer will automatically overlay the correct VE numbers in the cells effected by looking at your predicted A/F ratio cells and your wide band O2 readings. "
I'm a rookie here and I didn't see anything about this in the documentation. I take it this would only work while directly connected to the ECU. Do you have the VE table open when pressing 'L'? What's the proper procedure? Looks a very helpful feature!
Thanks,
Thanks,
