I pretty much followed this to make mine. I think I used a M10 nossle and I put it pre carb. I got the best response with only a 1/3 mix of alky and water. But I also mixed my fuel with C16.There are usually two ports one the compressor "foot". You can plumb everything off of one and then use the other for a injection nozzle. I worry that getting alcohol evenly to each cylinder would be difficult.
I went in front of the carb. I pulled the THERMAC temp sensor out and replace it with a misting nozzle. Some advantages are: no boost pressure to overcome, it's before the carb (helping with atomization) and it's easy. The easy part helps when you want to change nozzle sizes.
Keep it simple.
BEFORE BLACK - Alcohol Injection
where do you guys get the nozels at?
McMaster-Carr
