Stage 1 block, ROTATING ASSEMBLY, CHAMP INAKE AND HEADS
mturbo87
Mike
2,300.00 Block is 20 over with 2 center billet mains.
Stock rotating assembly
Crank is standard and rods are JE 20 over. Like new pistons with stock 2 dot rods,balanced assembly. 600.00
Champion GN1 assembly
New heads,1.65 rockers, port matched intake. 2,400.00
If your wondering, i merged all of your threads to one in case you had any questions, there is a 2 limit.
Thanks for understanding.
Look at the stickies at the top of the page for more information
BW :)
I want that intake! Let me know if you seperate it from the package. Thanks
Some questions for you. I tried to search to find out but now I’m more confused. Is this block ready to go If I get the block rotating assembly from you is it all ready to be put together or do I need to have it all honed out. Can I use my heads intake front cover oil pan from my 109 block or would I have to get stage I specific parts to finish the build? I guess what I need to know is can I take everything I have for my 109 rebuild and use it with this block.
Common Mike! Hook an Ohio brother up. please:biggrin: I would be all over this package if the heads were iron. If you decide to seperate the package, i'll be down to pick the intake up;)
All parts from a 109 block will fit, the stage 1 block needs a finish hone and I would have the deck cleaned up. I can have machine work done and build bottom end for a price.
I have a set of ported and polished steel heads if your in need. Their being cleaned up. I will let you know when their done.
You mentioned the deck needs to be cleaned up. Did the engine/block have a gasket failure or cam wiped, etc?
Thanx
