Where is the video of Todd's car spooling a gt4788 with a t6 housing and cutting a 1.19 60'. Those little twins will light right up.Going to be another one of my 206/206 like I have in Mikes car. : )
SignUp Now!Where is the video of Todd's car spooling a gt4788 with a t6 housing and cutting a 1.19 60'. Those little twins will light right up.Going to be another one of my 206/206 like I have in Mikes car. : )
1.2 ratio rockers and hydraulic lifters keep it in check.![]()
I count 8 seconds of spooling in that video..does not seem like a spooling rocket to me...
My mistake the spool time is 17 seconds from idle to 2 step and 3rd step and then to final launch, must be a heap of heat in that converter,,,
A couple updates, I am going to run twin Turbosmart 50mm wastegates . I swapped out the SLIC for a GN1 frontmount and will run a "Y" at the entrance for both turbo outlets. I am going to send out the ATR TT headers to SPD so they can cut off the ends and weld on a V-band fittings, this is so I can attach elbows and rotate the turbos down. The owner of SPD raced the Buick Stage 2 for years at Bonneville salt flats and knows all about them. I like the way NRE flips his turbos down and runs the downpipes under the headers, that will allow keeping the wheel wells. I don't have the skills of Mike E. so the small amount of fab work needed will be out-sourced. I have a couple of good shops in the area that can easily handle the plumbing, Bill Anderson will be tuning the car once its up and running.
View attachment 222920 View attachment 222921 View attachment 222923
