stall droped from 4600 to 2800?
oldguy
we lost 2000 rpm on stall, checked valves, leaked motor, checked w.g., checked vanes on hot side of turbo, 31 box, big stuff logs. a/f is @ 12.8--13.0,
t.b. is opening, plugs are good, no exhaust leaks are evident. need some help trouble shooting. anybody?
bob coffman
Broken sprag in converter
it's a built motor -- no cat, 3 feet of 5" exhaust, w.g. closed.
what's left?
Has the timing been manually checked?
Checking a converter on the bench without cutting it open is not the most precise way of checking it.
timing was synced and checked--okay. it revs normally in neutral.
can't think of anything else except converter going away. any more thoughts?
Can you post any data logs? Seems like the converter failed to me. No torque multiplication.
tried 2 high stall converters-----same result. stops at 2800 rpm. i'm thinking tranny man was mistaken. 2 hurt converters.
I have to say that the chances of 2 torque converters failing in the same manner and giving the same stall speed is rather slim.
totally agree! that's why we chased everything else so meticulously. i guess we send out the converter. thanks fellas
bob
