Stock downpipe exhaust elbow question...
sparko112
361
13
18
Ontario, Canada
question, I'm going to replace my original stock downpipe elbow with a stock ported exhasut elbow. Which bolts is best to remove first. I guess I should use ultra copper (high-heat make a gasket stuff) when bolting on the new elbow. What size are these bolts just in case if they break/And how do u guys get to the bottom bolt on the turbo exhaust side(one bolt in the back-bottom). I can do it, just asking if there's a method to start first.
out, looks tight?
wb_7354
372
65
28
A trick I learned is let the engine heat up. Wear gloves. A torch is no substitute for the warm engine. Pray they don’t break off
wb_7354
372
65
28
what's the bolt sizes for the 4 bolts on the turbo exhaust housing and the 2 big one's that bolt on the bottom of the elbow?
Iirc the elbow bolts are 13mm. The DP are 15mm. Hopefully someone will confirm.
Nigel
562
69
28
51
Nassau, NY
Soak the DP bolts in WD40, they will come out NP. The elbow bolts are metric, not uncommon but can't remember the thread count/dia. If you break the head off, a set of WR vice gripes once the elbow is removed should be enough to get the remaining stud out. I think in general the bolts will break right where the head interfaces with the stud. A little patience working the bolts and they may not break.
Steve-M
17
5
3
32
I’m trying to remove the elbow and it’s a pita... I got the top 3 out, one broke so I have to deal with that, but the bottom one I cannot get to, any trick to reaching that bottom bolt?
TexasT
Texas, Where are you from
Sep 10, 2002
4,590
373
83
117
Texas
ihadav8.com
Pull it off the car to get that bottom one. As far as getting them out, good luck. I cant remember how many broke but I welded a nut onto what was left and used an impact on it. Went back with never seize and some hex cap screws to make it easier.
grass doctor
630
237
43
44
saint augustine fl
I would soak all the bolts in penetrating oil for 2-3 days
retreating a couple times every day ,and thats a great tip to let the engine warm everything up
good luck
grass doctor
630
237
43
44
saint augustine fl
wb_7354
372
65
28
Op is from over a year ago. It’s good to see people are using the old threads to find answers!
wb_7354
372
65
28
Top Bottom
