O
OldGrayII
Guest
O.K. 1 of my Metric Allen Head THDP bolts is Stripped, Luckily its the TOP one, so how do I get it out?????????? The other three broke free OK and are out.
Originally posted by OldGrayII
Well its in my garage, and already half apart for my head gasket job, so taking it to my friends shop and welding another bolt to it is out, would it work if I used one of those reverse drill bit things????
Originally posted by The Radius Kid
If that doesn't work,a small flat blade chisel.Angle it to the head and hammer a small notch in the side of the head,then turn the chisel and try to rotate the bolt, hammering the chisel.
Yup,you bang your head against the wall enough,you learn to listen to the people who know.That's how I found out.Originally posted by TurboJim
YES! Johnny uses his knoggen!
Or try a..er...T35 (I think) torx..hammer it in. Head gasket? Yeowch!
"Or cracked head/block?!?!?!? Not always the head gasket...ASSume nothing!!!![]()
Hope it is just a headgasket...Probably is though... [/B]
