- May 27, 2001
I too would like to see an assortment of skins. I got used to the yellow and red.
From what I see (https://www.vbulletin.com/forum/forumdisplay.php/95-vBulletin-Style-Packs?) you can get free skin packs and if you search for skins in google a whole slew of websites pop up.
Is there something with the VB version installed that prohibits the use of free skins?
VB4 uses a completely different skin format than VB3 but if theyre for VB4, then they would work. However, out of the box they are not going to look "right" and would need editting to have a fluid appearance.
Other problems are any time you make a change that requires a template edit, you have to edit every one by hand. I had to do that on the old forum and it was a pain.
Im not interested in adding free skins here. Theyre more trouble than theyre worth usually. If you guys want to pitch in money to have the old format ported over, Ill get a quote from the artist I work with. I figure you're probably looking at around $500 to have it done.
