- May 28, 2001
Lookin' good!
SignUp Now!I like the trans mount you had done with the stock crossmember. Makes me want to rethink what I've done. It would definitely save me some weight. The trans dip stick you suggested further up hugs the transmission really good...I bought one. I also saw the modded extension housing you have for a speedo cable on ebay. Thought about getting that but since I have an electric speedo, I can probably get an output off the trans speed sensor to get a 4000ppm for it to work. At least that's what I'm hoping to do. I'm still slowly working on my drivetrain refresh. Maybe in about 6 months or so I'll have it running.More progress today, crossmember is in (measure twice, drill once)
Dipstick tube was hitting the adapter plate, should have mocked that one up ahead of time.
Cooler lines partially run, shift cable connected, column linkage partially done.
Driveshaft in.
Harness connected and partially run.
I connected and 'bench tuned' the TCU previously, so that is ready to connect.. Connection to the ECU is just 4 wires.
We plan to finish tomorrow.
I'm jealousI plan to make some more vids of the tuning, anything else I should get video or pictures of?
A full list of part #'s and costI plan to make some more vids of the tuning, anything else I should get video or pictures of?
All this stuff should be in a sticky in the Transmission section for anyone that wants to tackle this.Here are the build/parts details. Scott built it, I helped out a little. Many thanks to Scott!!
Core is 1997 2WD from a pickup or vanrebuild kit from WIT (could use other sources) stock high-energy Borg Warner frictions, regular steels, paper&rubber, bushings, filter.selector shaft (convert from long to short shaft) -Sonnax 38511-03K4L80E / Th400 Intermediate Spring Retainer -- ebayreused original pan gasketdipstick TCI- 743805 , calibrate this during the build, full = .25" above pan railRostra replacement internal harness (34446)replaced IMS (manifold switch assembly) - GM #24222077 from amazonrollerized rear of case using TH350 bearing and sonnax bushing installed from the back (driveway engineer on Youtube)internal "dual feed", used cup plug in the case and set screw in the center support. remove second ring from center support and middle lip seal from direct.shift kit: used most of a "HD2 kit", used stock style plate from transgo 48-PLT-01 (since dual feed was done internally), drilled .093, .110, .093, .110 (2,3,4,R)drilled pump for line-lube and drain, drilled direct drum and installed return springs (all transgo HD2 procedures)clearance set tight at the back (.009"), the rest were setup 'stock', clutch clearances were set "stock" at about .060"teflon one-piece ringssonnax stator support bushing #34016-W , hone to fit input shafttorlon checkballs (installed all)reamed AFL in the valve body using transgo kit (48-ACT-TL)installed transgo TCC fix kit (4L80E-TCC)installed a 300PSI pressure sensor in the line pressure tap with a 90 degree fitting. (loDoller 'better' style sensor and cable)used the factory tool to set the reverse servo piston pin, chose pin 1 step tighter than the tool said to use.replaced overdrive planet, the original had too much slop in the pinions, bought on ebayused Dexron-VI fluid
I wanted a firm shifting street trans, so accumulators were not blocked and holes were drilled in the separator plate to accomplish this. It drives very well. I might experiment with firmer calibrations next season. I have a few thousand miles on it now and am very happy with the result.
Bob
Yes this build shouldn't get lost over time and buried in the site somewhere, i have a feeling a lot of people will be going this route in the future.
