Tach/Alky Mount
scot w.
GNSperformance.com
Here is our "Hidden" Tach/Alky mount for the Buick Regals. It mounts behind the gauge cluster surround. The mount comes with full instructions and all hardware.
Bracket is painted Satin black and is practically invisble when installed properly.
We are offering these at a 10% discount for the month of July only and that brings them to Only $16.20
Can be purchased/viewed here: GNS
GNS
Only 9 day's left Guy's! These are here at our shop and will ship the same day. No dropshipping!!
GNS
Is it possible to put two of these onto the side of the dash? Attempting to mount a 5" tach and a 2 5/8" boost gauge below it. just want to make sure it'll work before purchasing, as it doesnt really show how it mounts etc.
let me know? maybe possible to make a single longer one?
Thanks!
-DD
Thanks!
-DD
Yes 2 will work out just fine and it's actually better to use two than one long one and I will tell you why, using 2 seperate ones will be hidden better by the base of each gauge where as using one long one you will see the bracket between the two gauges. plus if you ever happen to remove one gauge for some reason you won't have a bulky bracket showing. I will be much cleaner..
SW.
I may need a couple.
How do I mount the alky box to the bracket---Felcro--screw--glue?
I used velcro, And when checking out if you specify (click the option for ALKY) I will include the Velcro already cut to size and send it with your order! ;)
Note: you must click the option for the ALKY bracket so I see it on the form, that way I know you want it for the Alky controler.
SW.
X2
Also do you sell these for just mounting an alky control only???
Yes in the picture listed on the Original post it has just the Alky controler mounted. Same pic as this one.
