TireFryer
The New Kid
- Dec 21, 2001
running a te62 with a 3200-3400 lu converter and on 24 psi pump gas and alky... its scary....
SignUp Now!I want to say 11.48 1/4 7.40’s 1/8 I had an art car 3200 that felt like a 3500 on the track .. it would nose down after the 1/8 . I never ran 28’s on that combo just 26 my dr’s best 60 was a 1.48What was ur ET? I have a TE-61 with a 2800 9x11 my best is 7.15 on pump gas and 20#
I will, is the te62 more capable than a te60? With the right converter cam heads setup?You guys should post your weight and combos.
What you need to really look at is what the turbine side is capable of and the weight of the car.hint 2 more MM of compressor even though the compressor actually makes the power,means little if your ex wheel cannot get ex out.I will, is the te62 more capable than a te60? With the right converter cam heads setup?
I have the .63 housing and a 3inch downpipe and 2.5 catbackWhat you need to really look at is what the turbine side is capable of and the weight of the car.hint 2 more MM of compressor even though the compressor actually makes the power,means little if your ex wheel cannot get ex out.
That some good trap speedThe TE60 is a great turbo ran 11.2X @ 120
I'm running the newer style 60 5957 11.2X @ 121
Billet precision wheel with Garrett exhaust housing.That some good trap speed
59 mm is this a turbonetics ?
MPH is indicative of HP...but if you can't get the HP to the back tires, you won't MPH well. I'd be more interested in the TC he's using.That some good trap speed
Ran a 13 year old 12" LU Neal Chance 2800 and ran a PTC 9.5 NL 2800...trap MPHs were the same. The PTC lowered my trap rpms 200...5500 vs 5700.MPH is indicative of HP...but if you can't get the HP to the back tires, you won't MPH well. I'd be more interested in the TC he's using.
Neal Chance and PTC 9.5 make great convertors. Convertors are the most important piece of the puzzle. Most get it wrong.Ran a 13 year old 12" LU Neal Chance 2800 and ran a PTC 9.5 NL 2800...trap MPHs were the same. The PTC lowered my trap rpms 200...5500 vs 5700.
Cant say I'm surprised.Ran a 13 year old 12" LU Neal Chance 2800 and ran a PTC 9.5 NL 2800...trap MPHs were the same.
The NC was $300 back in 2008. Not sure that equals $1000 today.Cant say I'm surprised.
