Originally posted by KwikerSilver
MY combo is as follows; Stock motor, 4 billet caps, head studs, rod bolts, tta pistons, tta crank, ported and polished heads with big valves, billet roller webber 206-206, t&d roller rockers, 70mm tb and plen and powerplate with the handling package, 55# injectors, 340 pump hotwired, v2 front mount, atr headers, racegate on mease 3 inch dp, atr 2 1/2 exh, and i am trying to decide what turbo, 45a, 63-1, 66-1, i am not sure yet.
Nicholas
Okay, Do you have TA heads, or GN heads on the TA block?...If yo have GN heads, unless someone decked the heck out of them, You are running lower compression than most of us.  That means you need more air into the cylinder than the rest of us to get the same power.  This may make the car a bit slushy on the street at low speeds.
In general, I would think you have a pretty good combination, but, I think your injectors are a bit small for the size of turbos you are looking at.  Altho I run 75# injectors, 65# units would probably be pretty ideal for a 45 size turbo that was going to be twisted to 26# or more of boost.
You did not say what converter you are running but it is very important to match the converter and turbo if you want to enjoy the car.
If you want to push the 530-540 hp that I think is practical for an ungirdled block, I think something in the line of a PTE53, 54 would match very well.  This will put you into the tens unless you weight about 400#.
A PT 53 is rated at 610 hp and the 54 at 620.  Your 55s will match up well with the 53 and I would suggest 65s for the 54.
I would suggest a 3200-3400 rpm stall converter that would allow you to build at least 10# of boost against the brake without taking all day to do it.
If you want to step up to a 45A or 66, then I would suggest 65-75# injectors, and a converter that will allow you to pull the 10# of boost at 3500-3600.
Just be warned that the 53 up are capable of flowing enuf air to blow the crank out the bottom.  The smaller the turbo, the more fun the car will be to drive in every day traffic.
These cars are all about combination.  If you get one thing out of line with the rest of the parts, they don't work as well.
