Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
Please look at my combo. 80's were in my car, popped the #5 cylinder HG last night. No water in oil, no oil in water. Plug wet, all others are ok within 5% of each other on compression test.
Had injector fault code on the fast, so evidently 80s will not work. I flirted with danger and it bit. I read over and over 80s would work 80s wont work, It really is dependent on the car. So again....learn from my mistakes.
It went from comfortable IDC to kill mode in less than 2 seconds. I think the car is opened up so well that it needs larger injectors and probably more pump. I really thought 450lph would have been good enough, but hey why not make that bigger too right?? Geesh, so anyways 120's good enough? Opinions thoughts please.
