Our new seperator plate has definately been a fix for the problem,but improvements elsewhere have been made.I have finally found the real causes of high gear failure with or without dual feeding with engines over 400 horsepower.It is related to the 3/2 control valve in the high gear circuit.There is now a mod that produces instant results for mismatched or poorly calibrated circuits within the circuit.There is no faster shift with no overlap at all throttle angles.The 9 clutch direct drums with full thickness steels have been tested and are now being manufactured,the billet piston has been made as well further improving clutch life,but this mod is phenomenal and has paid huge dividends.The information will be in our technical supplement as well as alot of other tech.The 3/2 control valve fix will soon be updated into the shift recalibration kit as well.Also we are running the billet forward drum with a 30 spline shaft and a matching ring gear.
