- Nov 24, 2001
ok went ahead and replaced the thermostat, figured since it looked old it may be time. replaced the gasket that goes around the round thermostat housing as it looked worn. now with the car warm after running more then 10-15 mins neither hose seemed warm or hot. next would be replacing the heater control valve since it may be the original and i'd like some heat in the car being it's winter. 10.00 at oreilly's and seems real simple, any other suggestions since i'm in the trying to narrow down why it's not heating inside the cabin. thanks guys for your help in advance.
Make sure the coolant is filled all the way, if you filled it and have a air pocket, possible it is not getting all the way thru the heater core.
That is not the original heater control valve, the original was metal.
Ok when you go to replace that heater valve, you need to make sure the heater core is not plugged up, its possible that it is completely plugged with sediment and corrosion.
Try using a garden hose and run water thru it to varify that it will allow water / coolant to run thru. I would not try compressed air, you will damage the core.
If the heater core flows coolant, replace that heater valve, and varify that it works(does it have a mechanical arm you can physically move) top off the coolant and you should have cabin heat.
Post back what you find
BW
