Phoneguy
Cometic HG stress tester
 - Aug 27, 2002
	You can leave the top open or T like this
Bryan
	This configuration got me 31 psi boost before I lifted.If it is moving freely , install the 7lb spring( this is what I use as well.)
Output from turbo to input on controller, From output of controller to bottom port on gate.
Bryan
If you're looking to run lower boost you will need to open the waste gate bypass. If you decide to use an external pressure source with a boost controller you can use a light spring and the strategy i messaged you with . The simple fact is you can't have a wastegate that is adjustable over a wide range of mass flow without a lot of playing around and having good control over the pressure on the gate .The ex energy will be out of the wastegates controllable range if you are trying to run it to far from where it's really happy. That turbo will go over 70lbs/min on the right combo and will support about 150hp more than the old one. If you were to measure back pressure before and after the change you would find that what you have now has less back pressure even at higher pressure ratios. The compressor is biting off more air and it's taking less energy to drive the compressor because the wheels are fairly well balanced in flow. Therefore you actually have higher boost pressure and less backpressure . Perfect for making a lot of power .Well it was too rainy to test drive today but I did get a look at the wastegate pipe to downpipe return connection. Took an I-Phone and a flashlight and stuffed them down the pipe with the phone filming. The connection looked pretty good. No significant lip anywhere. Total area of the opening is definitely more than the area of the wastegate pipe cross section so I don't think it poses any real flow restriction. My wife can actually fit her hand in the downpipe and feel the opening where the wastegate pipe comes back in. Will try to do the test drive when the rain stops.
Yes, still 26 psi boost.have you drove it wil the turbo connected to the gate? no controller?
If you are still getting 26psi without the controller and a 7 lb spring, your wastegate is not able to handle the pressure correctly. What wastegate are you using?Yes, still 26 psi boost.
