Flyin Brian
- Jun 18, 2011
I did some searching on here and I think I know the answer but wanted opinions. I got my turbo upgraded from a 58 mm compressor to a 62 mm compressor. Garret .63 exhaust housing, .60 compressor housing, 65 mm turbine, GN1 3-1/2" downpipe with 46 mm external wastegate. With the old turbo and old cracked ATR headers and both the large 13 psi blue spring and small blue 7 psi springs in the wastegate the boost would max out around 25 psi. I took the large 13 psi spring out when I put the new turbo on and left only the small 7 psi spring in there thinking that would be safe. Also installed the TA headers. Did a run and the boost went up to nearly 28 psi. So, I ran the wastegate with no spring and took the hose off the top port so the gate is open all the time. Ran it again and the boost still went up to nearly 26 psi, slow spool-up. Wastegate hole is already at .950 inches now. Pipe to external gate is close to 1.125 ID. Do I need to port the hole further to get the boost down and controllable? I ask this as at 25 psi boost I am already out of injector now and running lean. Would like to run around 23 psi for now until I can get bigger injectors. Shift RPM also went up from around 5800 to 6300 but my converter is way wrong for this combo. New turbo seems to be moving a ton of air! Rest of build in my sig. Thanks.
