daredevil95
- Oct 21, 2012
Hi, I just installed a used low mileage 200R4 trans into a 86 GN, I'm having a problem with the TV cable, the cable keeps slipping off the tiny rod that hooks into the TV cable at the transmission under the car. The TV cable is a Highway Stars cable that I bought in 2016 and seems to be in decent condition. The TV cable connects to the TB with no issues and adjusts properly and locks so, what causes the cable to unhook at the transmission under the car? It's driving me nuts, I have to keep jacking up the car and reattach the cable, it falls off within 5 minutes of driving and there is tension on the rod coming out of the transmission, I pull it up with needle nose plyers, hook the rod into the TV cable with no issues, it snaps back into the transmission and there is tension at the other end of the TV cable at the TB(springs back) but, not for long. Does anyone know what I should look at to fix this? I was going to drop the pan and check out where the rod connects to and see if there is an issue or buy a new TV cable....IDK? Any ideas?
