SignUp Now!So what do you think? Do I need to start throwing more crank at this thing?
... 3300 lb car on 10.5" tires with a stock type suspension. How much torque do you really need?
As it is with the Stage I motor, I cannot use all that is available from that motor at the launch. I do have to control it back. I'm guessing I'll have to pull back with the Stage II heads, too. I'm guessing stroking it would be a waste, if I'm already pulling back.That depends on your track. But for the tracks here in the south east where a lot of 10.5 class racing happens, you can put down a lot more than you would think. Guys with 400"+ engines can leave with 6-8 lbs. of boost on a true 10.5. That's most likely near 1000 ft. lb. before the converter, trans ratio and rearend ratio does it's work.
If you can make the same power, but more torque with less stress and wear on the engine what is the disadvantage. It's always easier to back off the power than it is to try and squeeze out more.
One consideration that I feel is very important when going with a stroker crank, is the split wrist pin arrangement of the even fire crank. I believe that the split pin arrangement becomes weaker as the stroke is increased. Consequently, the split wrist pin arrangement is stronger as the stroke is decreased. To me, that is a much more important consideration than what the rods will have to go through at high rpm.
At this point, I'm not interested in building an odd fire motor. I like the sound of the even fire with tuned exhaust too much. If I were building a max effort low seven second attacker, then I would seriously think about going that route. I also have to add, that I think in that sort of situation, odd fire would be the only way to go.You could build an Odd fire motor. Several others have gone this way. Then you wouldn't have to worry about the structural integrity of the crank as the stroke length increases.
Neal
There's room for improvement after the launch and on the top end. Particularly on a good track. Besides, I just have to do this Stage II deal.Using that justification wouldn't you just stick with the M&A heads? Are you saying you don't want to make more power?
The plan is not to take the motor up to 9,200-9500 rpm on every pass. I'm really thinking that what I'll end up doing is have a special 'killer' spring set on the shelf for special events, or whenever James calls me outIn reality you would break the crank due to cyclic loading. But the math for that is more involved than I want to look at right now. But the two factors that determine life cycle are cycles per second and max and min load. When you turn the rpm up, that cycles per second number goes up and life goes down. It's a trade off. Short stroke crank with more area, but high cycles per second. Or long stroke with less area but lower cycles per second. For two motors that make the same power, they likely have the same life.
