Donnie, we are building 2 different engines mine is for daily street use and yours is full out race. You do not need to go that high rpm, just turn up the boost? Redo your sim with 40 psi boost target, and overlay 30 psi, Mike runs up to 60 psi!
SignUp Now!That's correct.Donnie, we are building 2 different engines mine is for daily street use and yours is full out race.
The sims I've been doing have been with a boost target of 45 psi. There is no extra exhaust capacity being dumped overboard. Besides, if that wasn't the case and I could have the boost ramp up quicker in relation to engine rpm, cylinder pressures would exceed my limit.You do not need to go that high rpm, just turn up the boost? Redo your sim with 40 psi boost target, and overlay 30 psi, Mike runs up to 60 psi!
That's correct.
The sims I've been doing have been with a boost target of 45 psi. There is no extra exhaust capacity being dumped overside. Besides, if that wasn't the case and I could have the boost ramp up quicker in relation to engine rpm, cylinder pressures would exceed my limit.
If I could get the boost to ramp quicker with the small displacement, I would need to drop some CR to get cylinder pressures below limits. The lower CR would add to spool up difficulty.
You are right, Mike. The longer stroke does move the torque curve left. I was a little surprised to see how drastically, though. It also tops out the compressor capacity and head flow capacity sooner.
The redline of the stroker motor would end up being about 1,000 rpm lower, as you eluded to in your post.
Maybe a 3.4" stroke wouldn't be a bad compromise.
I'm already using the maximum shot size I can use for a nitrous/methanol mixture. And lowering the CR would make the existing nitrous shot less effective. With the cam specs I'm going to use with this new combination, I don't need anything making the spool up less effective.Sorry for the confusion, I thought you were targeting 30 psi on your new build. I think lower CR is a good idea and safer. Could you just not use more NOS to spool the turbo quicker?
What sort of parameters are you not sure of? Let's see if we can't straighten those out.I am starting to think the free trial of the sim only gives a small portion of what you are using. I tried it, but it won't really give any intelligible data because I can't plug in everything required. I'd be curious what my junker should be turning out, and see if I need to change any variables before it is too late...
I edited this post (#119) to include some descriptions of what specs were used in this comparison sim.Norbs, you obviously have a different idea of what makes a racing engine. To each their own.
You build your engine the way you want to, and I'll build mine the way I want to.
The light blue and red trace lines are using a 3.625 stroke with a 218/218 dur, 115 l/s camshaft. It was installed somewhere between 3-5 degrees advanced.
The green and dark blue trace lines are using a 3.06 stroke and my crazy cam specs.
Both are using my manifolding specs, although the manifolding specs are having far less effect with the smaller camshaft.
Both are using the same turbo. FI91X.
If you're having problems with a parameter, the meaning, or what number to plug in, I can help with that. If there's more than one that is giving you problems, we can simply go over them one at a time. I admit the turbine nozzle is a grey area without some real world data to compare against the sim, but even without real world data to compare against, you can play with a realistic range and still get useful output. I can help you with measuring your turbine housing to get you close.Well, without all the parameters in there, the results are pretty blah to say the least and will pretty much tell you your stuff is going to end up in a bucket for scrap. I am still learning the software, but it really takes looking at a required parameter, running out to the garage to take some measurements, and plugging them in. I am at work right now, so don't have access to it, but I am sure I can take measurements to come up with port sizes, intake tract sizes, header tube diameters, etc, but I am unsure of nozzle size for one thing; that is about the only thing I can come up with off the top of my head... The software is crazy detailed, which is good, but let's say you don't have the entire cam card in front of you. It is difficult if not impossible to get any good info out of the software. Seems it is the same situation with regards to cylinder head flow, or backpressure, or backflow ratios, etc. There are some terms I have never even heard of, but luckily some of those are grayed out and don't need filled in. I will have to play with it some more and see what all I am lacking to be able to get good data...
If you're talking about the last comparison, I did note that I used the FI91X for both engines. The 4.1L engine, with the small cam that was used, did not develop enough exhaust energy to push the FI91X to the same boost that the smaller engine was able to push the 91mm to. That is why you are seeing the large HP difference.Donnie, I am sorry but i don;t believe going to a smaller cubic inch with a bigger cam is not going to make 500 hp more than a 4,1 engine , with a 3.625 stroke, with the same boost, you have made some errors somewhere in your calcs.
I am using an air to liquid intercooler that is running dry and blocked off. I am just guessing at 45-55% eff. Basically, it just acts as a heat sink that quickly heat soaks.Air to water IC's are about 65-70% eff and water at least 80%+ but real world data is best.
Norbs, could you clarify the above quote. Do you mean air to air at the beginning of the sentence and then air to water for the 80% eff?Air to water IC's are about 65-70% eff and water at least 80%+ but real world data is best.
