Dusty Bradford
- May 24, 2001
Who's to say a 3.625 stroke can't turn 9,000 rpm??
SignUp Now!That's kinda like saying, who says a 200-4R can't stand up to 1,000+ hp?? Or, building up a 109 block to do 8s.Who's to say a 3.625 stroke can't turn 9,000 rpm??
Traction may not be as bad as you think. Power will probably ramp in slower and help get off the line.I'm sure you're right. Unfortunately, for the turbo I'm using now, there isn't a smaller a/r ratio turbine housing available. I suppose I could see what Bullseye could do for me, if I find I want more after getting it running. Or, I could inject nitrous/methanol directly into the turbine housing to create extra exhaust energy to drive the compressor harder. That nozzle is already set up and being used to spool the turbo. I could simply keep that one nozzle on to feed the turbine housing for the duration of the run.
But the real limiting factor is going to be the cylinder pressure. Not so much a problem with the stroked configuration, but then max rpm becomes an issue. I want to build a screamer.
What I'd like to do first is get the engine running and tuned to the limit of what it can do up to 40 psi, get some track results, collect some data then decide where to go after that. It could very well be that my chassis will have a hard enough time as it is with the projected 1400 bhp.
Traction has not really been a problem at the launch. Actually, I could use a little more power about 15-20 feet out. Power wasn't ramping in quick enough. A problem associated with having the boost ramp-up closely tied to the rpm ramp-up. The ramp-up association was very safe. There was little chance of ending up with too much boost at too low of a rpm. Still, I was able to coax a 1.27 60' out of the car.Traction may not be as bad as you think. Power will probably ramp in slower and help get off the line.
Allan G.
It might. But, for how long?
Split journal.What's different in a Buick than every other engine in the world that doesn't allow it to turn 9000 rpm with a 3.625 stroke when there are engines with more stroke than that turning that same rpm?
The issue of the split journal 3.625" stroke has nothing to do with the engine being 'built right'. The issue is the cycle life of the part. Lessening the area of the split journal AND pushing it to extreme stress levels (high rpm) has to lower the cycle life of the part. For those shooting for a record, and can afford to pull an engine down after so many cycles and have the crank checked for cracks, I'm sure it's worth the expense to them. For me, I can only afford to worry about valve springs. I expect this engine to last around 3 years with nothing more than valve adjustments, oil and filter changes, and maybe a valve spring set replacement.Hmmmm. I know of several 3.625 stroke engines turning 9000 rpm. I have never heard of a problem with it if the engine was built right. To me if rpm is the issue then it's time for more stroke...less rpm....same power. Benefits will be extra low end torque and increased reliability.
3.73:1 with 29.5 x 10.5 - 15W tires. Actual running diameter 28.4" with a 3.3% tire growth. With the present TC, 12% slippage, should cross the finish around 8500-8600 rpm.Donnie what gear is in your car that will bring you to close to 9000 rpm at the traps?
I know, Norbs.I would talk to Dusty 12% slippage is unacceptable.........the ptc units slip about 3.5-4% max.
Didn't Neal bring up that he recently came across a couple of stroker cranks that had cracks in them? Obviously coming from a source that had learned when to change out their stressed to the limit cranks before the whole engine got taken out.
The fuel demand for a 1500 hp target using a BSFC of 1.35 for methanol fuel will be 2025 lbs/hr.
I plan on using 2 large Weldon electric fuel pumps, 2 - 160 lb/hr electronic injectors per cylinder and one mechanical nozzle per cylinder. This should cover the fueling needs.
