Reading thru some older threads i read lots of different compression ratio's and different timing curves but not all on same fuels i see what's safe on these engines on timing advance for pump gas and pump gas w/ alky but how about ethanol? ive seen someone on this forum say they have ran almost 30* + on ethanol is this true? no clue on compression ratio on that comment it was on the e85 thread.. also need some compression 101... what helps get the power on ETHANOL (alcohol based fuels) how high can you go on alcohol based fuels.. can i run higher compression with less timing would this be more beneficial to make power? or is running standard compression somewhere between 8:1-9:5;1 at what point is too much timing hurting performance who runs high compression on this forum? anyone run above 10 to 1 compression with good fuel? im having trouble understanding the timing vs compression thing.. why not run higher compression with less timing make the power with less boost... lastly has anyone ever tried a hemispherical design head on a buick engine? im not an expert if i sound like an idiot to the 25+ year engine builders i apologize but i have to learn somewhere and i dont want my pockets to learn the hard way..thanks,
