Sorry for the double post. I already put this one in the Transmission section, but no response...
Previous owner says he had the stock transmission re-built, not sure who did it. Trans works fine, although auto shifts hit pretty early.
Main problem is stall RPM is very low, so it is hard to build boost at line. SM indicates max RPM = 1600 with foot brake and WOT. Only makes about 3 psi boost.
Does this mean the torque convertor stall RPM = 1600, or are there other factors involved? What torque covertor would be better? Car is mostly stock except TT pump gas chip, 42.5 inj, 3" DP, Pypes exhaust, 340 FP & hotwire.
