these ?
in your picture, the switch on the left is the main rev limiter, and is set for 6000 RPM the switch on the right is the "trig" or "2-step" setting and is set for 3000 RPM.
Bob
these ?
Clarify something, You are trying to use the FAST 2-step unit with the TR6?
I'm not sure that will work properly.
Bob
.....It's just like your old box that plugs into the fuse panel. .....
I thought I remember you saying it would work with the new box.
Yes the tr6 throws a code 18 and does it when the fast 2 step is activated. I would prefer to use the xfi to adjust the 2 step. Is there a flash Available soon?no, I never said that.
likely the TR6 will set a code 18 (blown fuse)
it may work "ok". but my 2-step is designed to control the stock ignition strategy, so if FAST copied it, then that is likely how theirs works.
there are numerous technical reasons why it may not work properly. (which I shouldn't discuss in public, I guess....)
Bob
yeah, I'm going to look into it.
Bob
