Track Rental on 3/22? Whos going
my1stgn
Im already signed up and hoping to get some good runs and tunning done! Anyone going? Don, Mike, Chad, any one of you slow guys going:biggrin: Im opeing to prove those people wring that said my car is good for low 12's! Come on 11's!!!!!
i'm hoping my car is sold by then :).. a have a guy flying in on the 8th (i hope) to look at it.
what's a roll pin?:confused:
A Roll pin is a dowel pin made from a thin strip of rolled sheet metal instead of a solid dowle pin, and are notorious for insufficent shrear strength and generally shear off when you least want them to. A lot of pins used inside the distributor that either locate something axially such as the distributor gear drive, and or start or stop a movement are dowel pins and do shear. Generally designed for low shear or strength applications.
I'm considering doing this with my "New! Improved!" Limited but that depends on getting the tranny done between now & then; after 205,000 original miles it has finally developed one a heck of a 1-3 slide at 23 psi. ;)
Reply
Which track are we talking about ? I know Bob is itching to run the TT car. please let it not be another Bakersfield fiasco.
I should have it back together for that. How do you get on the list?
Awesome! what time you guys leaving Don? Will Chad have his car ready by then? I know he said he was going. Good to see a few GN's out there ...... too bad Ill be the slowest one out there!
We're going to try to get Chad's ready. Haven't decided on a time to leave yet. Maybe we can caravan. I'll want to get up there early.
Well we want to leave early to so we could have a little prep time. I think gates open at 8 so I wanted to leave here no later than 6am. A caravan sounds good. Maybe we could do breakfeast too before we love or something. Hopefully Chad takes his car, I need someone to push me!:D Let me know what time you guys are going! Im still trying to put in a posi, axles, and a few other mods before we go!
