Turbo__Tim
One heck of a Tim!
- May 25, 2001
Well I'm happy with the 60' times (1.7, 1.8's) but 13.1 @ 99 mph, (@ 18 psi.) is a tad slow for this combination, even with pump gas.
Ed Baker and friend Steve were there, and helped out a bit. (thanks guys!) We upper the FP, and tried a Lubrant chip. Ed has an impressive chip collection....
Adding to my embarassment were two other turbo buicks that were kicking my butt, with very mild combinations. This was not a 'mood enhancer', and I avioded the subject matter of what I was running. Sheesh!
Of course today I figured out the problem.
A couple of weeks ago the 340 fuel pump went. I replaced it, but didn't check where the 'knock point' was with the new pump. Apparently the old pump had been operating at much less 100 percent, when I determined the knock to be occuring at 14 psi. Since this was a new combination, I just went ahead and adjusted the alchy turn-on point to be 12 psi. I could only use 1/4 the speed control on the SMC, however, and maxed out at 21 psi.
Interestingly enough, the EGT's, and 0-2 readings were normal, I guess from adding the alchy.
Today I determined that I was getting no knock at 18 psi, and set the turn on point to 17psi, temporarily.
25 psi, no knock!....Yeah baby!
Back to Atco Tuesday, with an extra 7 psi.
Who's your Daddy!
Who's your Daddy!
