Whats the max amount of play that the Turbine Shaft can have before asuming that the bearings are bad?My car's new Boost Gauge is showing vacume but no boost ,even under full throttle.No vacume leaks,all new lines,no Exhaust or Intake Leaks,Carb Secondaries work fine,No Oil leaks or smoke and car runs great.WTF?I took the exhaust elbow off the turbo and started the car and the turbine wheel spins but kinda binds a little by hand and I can move it back and forth about an 1/8 of an inch or more.Would that cause it to spin not fast enough for no Boost??Can anybody figure this one out?
