SignUp Now!........ I feel like I walk the car inside and out like a pilot looking over his plane before I take it out. Lol.
Sent from my SAMSUNG-SM-G900A using Tapatalk
alky is also octane so if you have good 02s and are knocking you need to add enough alky to suppress the knock and or make sure your seeing pump pressure soon enough,having the alky on 4 can lead to slower pressure and not knowing when full pressure comes in with an overboost situation can lead to a bad day. usually with razors kit 6 on the alky and tune afr around that.if you truly want to understand/prevent you need a fuel pressure gauge off the rail and on the alky system.logging after the fact will allow you to see what has happened also but its not in real time.now understand having a fuel cushion will allow the car on a colder night to eat more fuel and you need to anticipate more as the driver and tuner.the O2s were still fine but the knock was over 5. I was like wtf.
Trying to replay that moment in my head and I'm thinking the goose or blip was quick enough to where the turbo spooled and built boost but the transmission was late to the game and hadn't downshifted and kicked in yet. Probably not smart to do this. Yes, the alky, turbo, downpipe, etc, etc were all installed last week so I'm sure it was recently primed.how much of a "goose"?
with a tune at 22-23 psi, an overshoot to 25 does not sound unusual to me. You might have some alky lag (was it recently primed?)
If it were me, I would carefully investigate the issue and tune it out. I.e. run on the rich side and over-alky'd until this is understood and eliminated.
Bob
Once you verify fuel pressure and alky pressure is there,then you can start looking into the other fun areas that can effect the knock gauge.I did get one time where the O2s were 800 but knock hit 15!!! That has to be false, right!?!?! Something rubbed or hit somewhere??
40 degrees.How cold was "cold"? If the intake was too cold the alky might not be vaporizing.
