I have a PT70 on my car and I am having problems with compressor surge thorughout all throttle ranges now. It used to be that the compressor only surged at WOT but now it is doing it at partial throttle as well. I have a fairly stong build with some big parts on the car so I do not think that the turbo is too big but I could be wrong. Here is a list of a few of my parts:
- built shortblock with Eagle crank and RJC girdle
- .020 JE with floating pins
- P&P 8445 heads with 1.77, 1.50 vavles
- 224/220 comp hydraulic roller with comp "beehive" valve springs
- T&D 1.65 roller rockers
- P&P stock lower intake
- 70mm upper plenum and TB
- CAS V-2 front mount
- 83lb. injectors with TurboTweak chip
- MAF Translator +
I am really frustrated with this problem and would greatly appreciate help with a solution.
Thanks in advance.
- MAF Translator +
Thanks in advance.
