SignUp Now!So what exactly are you trying to accomplish by going dual? You can try a small turbo and a large turbo...the smaller to spool up and the larger for top end. I really cant think of any other reason to go with duals, other than the wow factor. Just about anything a dual setup can do, a single turbo can do, if set up and tuned right.
Yup exactly, if those are stock turbos on a 3.8. Could you go into detail on your setup? JayC
Wow thats an impressive setup. I dont really follow your alky and gas system, I guess you are injecting alot more alky than in a typical water methanol system. I also assume that the alky is turned on at a predetermined boost level? The link you posted showed the car in development stage, I saw a 10.15 time posted have you ran that car recently? I also noticed that you dont have much in the shortblock, do you think the engine is reliable at that level, or is the alchohol helping it live?
Has anyone tried or know of someone who tried using 2 stock 87 turbos on the 3.8 buick? If so, what would need to be done for an mass airflow sensor and what size injectors would support the airflow?
Obviously you can use any turbo you want, but to use two stockers doesn't seem worthwhile. Our current system powers a Buick to 800 hp. And these are relatively small turbos. We run the can through a full exhaust and race it as we drive it. The only change being tires and gas. We have Dyno'd the car at 10# and made over 450 hp. That same 10#s of boost ran the can into the mid-low 11s. We recently slide off the line at Cecil in 10.5 second @ over 130 mph (18 psi):wink: . Again these are tubos that are larger than stock, but not that much. We chose this route because smaller turbos would yield less power and then you could have an argument that the single is just as good. Singles are very responsive unit the 500-550 range. The twin set-up should start there and go up in power output.Im just not certain about the amount of lag and power potential there is on a 3.8.
