Quote:
Originally Posted by TurboBob
at lower rpm it will not help, as the coil charges up to the limit imposed by the ignition module.
I need to look back at my notes, but the coil on my car charges in about 3 ms if I remember correctly.
There is a minimum off time which I don't remember, but its probably .5ms or so.
So we start losing spark energy when the coil doesn't have enough time to charge.
the coils charge and fire 3x in one revolution.
6000 RPM is 10ms for one revolution.
if the time between coil cycles is .5ms, then 3 + .5 + 3 + .5 + 3 + .5 is the total time required to fully charge the coils.
thats 11.5ms, which is 5217 RPM. Above that (based on my theoretical numbers and fading memory) we lose spark energy.
With higher applied voltage, the coils will charge faster, extending our range.
Note also, when they get hot, coils charge more slowly.
Bob
didn't RJC start addressing this already with there mega coil pack design getting rid of the waste spark by using 6 coil packs instead of 3 your gaining 50% charge time unless im not understanding somthing right
Bob
Bob
I understand the dwell time for saturation of the coils is gonna be less as higher rpms.
But one would think that it you use 14 volts at the primary VS 11 volts the more voltage will make a difference all the way up.
As we noted last night The output voltage was always 2 volts less than the input voltage.
so if the input voltage is say 12 volts that means the coils are seeing 10 volts. then there is the current limiting issues. but i can't see how the current limiters are being a issue if the max output voltage on the limiter is not met.
I also understand that as the coils heat-up the resistance goes up.
BTW i love a good tech discussion!
