I tired to upload pictures of the carnage but for what ever reason I am not able to, I'll keep trying.
This is what I found, after removing trans due to a soft 1-2 shift. This was a recent rebuild that worked flawlessly then it developed a soft 1-2 shift.
-Low reverse clutch, friction is flaking off. (don't recall what manuf.)
-Washer between forward and direct drum melted
-TV modulator upshift valve was stuck, needed to use picks to get it unstuck.
-O/D clutches burnt
-Band has heat marks on it, slightly bent anchor too.
What do you pros recommend Alto frictions throughout or do I use Borg Warner or Raybestos in certain areas.
Parts I already have are billet forward drum, hardened stator and sunshell, 7 vane pump, Superior super servo. Kolene steels, CK's re-calibration kit with manual t-brake.
Do I use the Kolene steels or not? I see mixed reviews on Kolene's. I'll be using the Alto Wide band with welded anchor and 300M band pin for sure. Anything else I should get while I am at it in terms of hardened parts specific frictions etc....
Mods in Sig.
Regards,
Jim
-O/D clutches burnt
Mods in Sig.
Regards,
Jim
