getchasum
MISSING 2 CYLINDERS???
- May 23, 2002
Would there be any concerns with taking a set of center billet caps from one block to another?
SignUp Now!Just my own opinion...
I would definitely have concerns, not necessarily because of the compromised strength of the caps, but rather the caps being honed for THAT specific engine block. I would just up the coin (for my own peace of mind) for new ones for each rebuild...
I agree with Dave. It's just steel. ANY main cap installation job NEEDS to be performed by a competent machinst. Key word is "competent' a.k.a. highly skilled. You just cna;t remove them and bolt them onto another block. Even new, the steel caps need alot of hand fitting/machining to do them right.
while you guys are talking about steel caps i have a question------i haven't really done too many of these--------any time i felt the need for something like this i have always gone the girdle route------- i am working on an engine for someone that had a set of these caps installed------there was terrible fretting at the junction of the cap/block-------the registration appears to be done correctly-----ie fits tight like a stock cap and has to be lightly driven in with a dead blow hammer-------my question is whats with the oversized holes-------whats the sense of making a hole for a 1/2 inch bolt thats nearly 9/16 ?????------really puzzled me so i machined sleeves, pressed them in place and reamed them to .503" in hopes that it might prevent some of the "walking"--------is there more than one company making these things and perhaps this is a crummy set or are they all this way?????.............RC
Honing is not enough. The hone will follow the shape of the bore. If the bore is not straight honing wont correct it. This goes for any time you switch caps on any block. A line bore must be performed.I was thinking the same thing, that's why I posted. I didn't know if once installed on a different block if having them rehoned would correct or create other concerns.
Still would like to hear other opinions or from those who have tried it.
The oversized holes are due to the required fitting of the caps. They are NOT a bolt on deal. Most of the caps I have seen installed had the holes in the cap elongated to get the registers to align. (especially the thrust cap) I, too, prefere the girdle approach. DLS likes steel caps. He says the girdle approach prevents the caps from walking, but hasn't found the girdle to be alot better. I feel that if the girdle stops fretting, it's doing it's job, and I can use the stock caps. (after machining them flat) Anything that strengthens the bottom of these engines is a good thing. I think the time (labor) to install a girdle is more than just adding steel caps. Especially during assembly of the short block. The steel caps require no more time to assemble than a factory cap block. BUT.......the machining required to install the steel main caps is SIGNIFICANT! You have to machine the actual cap holes, so they align correctly, machine the cap registers in the block and on the cap, align bore, and align hone to proper size.
To install a girdle, you only need to machine the caps flat, face the caps .002" (to allow material removal during line hone) and verify pan rail to girdle dimensions via laminated shims. To do it PERFECTLY, some machining of the pan rail may be in order. I will sometimes hand sand a 109 blocks pan rail to get a near perfect .005" gap all the way around the pan rail. Stage blocks are a bit too hard to sand easily, though. A 109 block sands real easily with a flat sanding block and 100 grit. I have the caps machined flat by a competent machinist (non-automotive), and have them grind .002" off of the parting surface to clean them up, and give the automotive machinist something to remove when align honing. I then fit the girdle in place and torque it all up, and drop it off at the machine shop, and pick it up a few days later. All the machinist has to do is take a light pass through the block with his hone, and hand it over to me.
Richard,
I guess that maybe you got lucky on that block but the stock machining
is a crap shoot at best. I have had plenty of blocks with bulkhead core
shift so bad that I had to slot the holes. I have also experienced many
blocks with the bolt holes so far off that the studs wouldn't even start in the
threads. It is more important to have the caps in a relaxed state and sit flat
on the block then to have them side loaded from poor factory machining.I
think that the fact of the block bulkheads being so thin plus a casting joint
running through it doesn't help either. I have see plenty of aluminium blocks
with locating dowels and serious fretting ,it's the nature of the beast . When
trying to make 1000 + HP out of a block that wasn't designed to do such
you make do with the best you can. When Dave Bamford took his stage 2
twin turbo car to the Hot Rod power tour dyno challange a few years back
and put down 970 at the rear wheel on 5 cylinders (broke a rocker during the pull)
there happen too be a retired GM engineer observing he walked over to the
car shaking his head in disbelief when he saw that it truely was a V6 he had just witnessed.
I think he walked away mumbling something about that being impossible it just couldn't be.
