May 29, 2012 #1 R russ87gn Member Joined Jan 5, 2009 Messages 152 I just bought a vac brake setup after I put it on it doesnt seem to work right it stops decent but the pedal doesnt return fast it hangs up for a sec is there anything I can adj or is my master cyl bad
May 29, 2012 #2 C cruzn57 Still plays with cars! Joined Apr 18, 2002 Messages 4,867 did you change the pedal to?( you need to) look for push rod dragging on something, make sure you have some free play in pushrod and master cyl.
