sparky0798
- Jan 23, 2012
Looking for a vacuum block with extra port, gasket and screws for my brake conversion.
SignUp Now!Thanks Heisenberg. I know there's several vendors that sell them. I'm hoping to find one for a few bucks cheaper maybe if someone has an extra one.
Tee in to the pvc valve.
Looks much cleaner.
Run the vacuum line behind the intake under the coil pack.
Much cheeper
It the manifold thick enough to tap?Drill and tap the back of your upper intake plenum and install a vacuum port that's about the cheapest you can get.
I really wanna believe you but if feels so thin, I have my intake on the bench and pinching it with fingers feels so thin.It is. But you'll have to remove it to do the drilling and tapping. A tee on the PCV might be cheaper than an intake gasket, coolant and an oil change.
