VDO gauges, Lt-1 valve springs,....
SHADOWII
1/ New VDO gauges, vision series, water temp 100-250 deg.
Transmission PSI, 0-400psi-for checking trans. shifting pressures,etc.
Both are 2 1/16th", neither one has been used. took the temp gauge out of the package to measure for special gauge cluster mounting. no senders included. $55.00 shpd (using phantom gauges now)
2/ New Lt-1 springs(Kirbans)-$40.00shpd
3/ ATR-3" jet hot coated, down pipe w/external waste-gate 36mm works good. (I'm going larger)
4/ Mease17 row stock location inter-cooler w/shroud-$350.00+shpg
5/ 1/2" phenolic spacer for stock intake (believe to be PTE) $10.00+shp'g
6/ 1983 "T-type" turbo int. w/electronic carb.and distributor(1 used good &one dist. new) Make offers.
Lots of 86/87gn gn parts. Make offers.
i will take the spacer foe the stock intake.
this is the one that goes between the intake and upper plenum correct?
87 intercooled engine?
let me know where to paypal the funds
Have pics on...
photo bucket. Can't seem to down load to here. I'm going to try again.:biggrin:
Springs and spacer have have sold.
Still available are :
s/s downpipe
VDO gauges,
mease slic
Ls-1 maf
universal drive shaft welded loop
still have lots not mentioned. Just ask!:cool:
