1/ New VDO gauges, vision series, water temp 100-250 deg.
Transmission PSI, 0-400psi-for checking trans. shifting pressures,etc.
Both are 2 1/16th", neither one has been used. took the temp gauge out of the package to measure for special gauge cluster mounting. no senders included. $55.00 shpd (using phantom gauges now)
2/ New Lt-1 springs(Kirbans)-$40.00shpd
3/ ATR-3" jet hot coated, down pipe w/external waste-gate 36mm works good. (I'm going larger)
4/ Mease17 row stock location inter-cooler w/shroud-$350.00+shpg
5/ 1/2" phenolic spacer for stock intake (believe to be PTE) $10.00+shp'g
6/ 1983 "T-type" turbo int. w/electronic carb.and distributor(1 used good &one dist. new) Make offers.
Lots of 86/87gn gn parts. Make offers.
