TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Put a Walbro from one of our vendors in the GN last year. This pump can never keep up with 1 to 1 boost reference. Always about 5 lbs lower than it should be. Example, 17 lbs of boost, 43 base setting and I get 53 lbs of fuel pressure. Was told by the vendor that the relief valve is probably opening too soon and to punch it down. Sort of sucks having to drop the tank when the pump should have been good from the get go. A run I did a couple weeks ago I was getting 62-63 lbs at almost 30 lbs of boost.
Thankfully alky was making up the difference. Used the good submersible fuel line on the pump with the restriction cut off. Clamped correctly as well. Pressures were verified with PL and a couple different mechanical gauges.
My GN only has 34k on it with unmolested fuel lines, new filter, tried two different regulators with no change.
