TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
That's what I feel too, alky is maintaining af ratio. No volt booster and have one of those miracle 200amp alternators from the former owner of the "other" board.
SignUp Now!Mark, those alternators are not good. I'm not trying to dog on the parts you have but I have had a lot of issues with those alternators and now gave up on them. It might be a cheap trouble shoot to either borrow a known good alternator and/or a volt booster. I saw a common curve with my A/F once before and it was indeed the alternator, which was the same alternator you are using. I wish you were closer, I'd have you bring it over and we could test with some of my known good "for testing only" parts. Do you have someone close that could lend you an alternator?
to me it looks fine as long as it is flat like the boost and 1-1 .the FP is not dropping and it gained in the first example like the boost gained
Maybe you have the same problem I found with my fuel system this morning? Blew the hose off from the pump to the sender in the tank. Yours may be starting to go?
Got my old faithful one sitting on the bench but if I remember right had the same symptoms before. Will try throwing that back on. Was told volt boosters are a bad idea when running alky. Boost a pump that is dedicated to only the fuel pump might be an alternative.
With the little bit of testing I have done is the consensus that the pump is probably OK?
Mark,
Can you put the alky pressure sensor on the fuel rail? Just to see if you get the same results.
If the pump will put out 63 psi at 28lbs of boost what's keeping it from putting out 60 psi at 17lbs of boost? Are you saying a voltage issue is causing it to only put out 52 psi?
Ahh, gotcha, I didn't realize you still had the hood guage.
I think then next thing would be to get SalvageV6's test rig and verify that your pressure reg is 1:1.
Actually now that you said that I didnt take into consideration that is at 38# at 0 boost so really he's only a few pounds shy at 28#. I was thinking 43+28 instead of 38+28. I usually try to get an actual 1:1 but thats not horrible being 3 pounds shy. I still feel a simple bump in voltage will help solve the issue. I solved my issues with a volt booster but I'm running E85 so I'm not sure about the complications with the booster and alky.
I'm with you on that one! Might as well test the regulator first!![]()
