SignUp Now!ART CARR 2004R DEEP ALUMINUM PAN
ART CARR 2004R DEEP ALUMINUM PAN:eBay Motors (item 160350600941 end time Aug-21-09 07:30:02 PDT)
That looks like a really good deal on a trans pan...wonder how well the floor shifted shift cable brackets fit up against it? Anyone have a testimonial?
I'd like to see what you did myself so please see if you can find them.
wanted deep pan for 200r, and bottom sucker trans filter.
I don't have one, but these pans have been around for a while. This is the best price I have ever seen for a new one.
Inside the pan there are aluminum stands to hold the stock filter in place. To use a bottom feeding 700r4 filter, I believe the rear stands have to be ground down a bit for clearance. If you wanted to use one of Bruce's bottom feeder kits, you'd likely have to remove those stands all together.
Looks kinda what I was thinking about doing myself. Where's the bracket mount and how much fluid did it add to the tranny?
The PTS Bottom Feeder pickup wont work without Mods. in a Cast aluminum pan because it is much longer & sits at the very rear of the Sheet Aluminum pan. The Sheet pan has only one level and no divider. There's a Pic of the pickup in this thread.>> http://www.turbobuick.com/forums/transmission-talk/281500-pts-pan-pickup.html
Pic of Shallow PTS pan here>> Product Information
