Wastegate size ?
434nova
I am looking to upgrade my current waste to something newer / better. Right now I have a te45a turbo which is 66mm in size. I am running 2 turbonetics deltagates on the cross over pipe. I am looking to possibly changing my turbo to either a precision 6466 or a 70mm turbo. Whats is a good wastegate upgrade for what I have. Right now i am running 26 - 30 #s on pump gas and alky. Thanks
If you are running the turbo at 60% or higher of it's potential I'd run a turbosmart progate. One will easily cover either turbo on an engine flowing 70lbs/min or higher. If you want one pm me
Will this wastegate work with my current te45a turbo ? What is the flow of a te45a turbo. Its is from John Craig. Also what size mm is the progate ? Thanks
It will work well and 50mm. 45a will go to 75-77lbs/min on a the correct combo. Enough to run 9's
