Anyone ever bought a stroker kit from these guys? need some feedback before i go into my wallet
3.625 3.8L Turbo Buick V6 Stroker Rotating Assembly Kits
SignUp Now!Anyone ever bought a stroker kit from these guys? need some feedback before i go into my wallet
Just saw one make 500whp around 20psi with a relatively stock looking engine compartment with conservative timing on 93/alky. It had a lot more in it. Keep in mind this is a Weber machined and assembled long block that was tuned by Otto J. Not some random machine shop and wannabe tuner. There is usually a huge difference in result when you use top names on a project like this. For the timing and very close to stock appearing combo this engine was one of the strongest ive seen around. With more timing and better fuel this engine could have made 30whp more without any added boost. Mid 10 sec power on an iron headed engine at 20 psi. You dont see that too often on here.
actually i had it apart in many pieces replacing a piston but weber did build it first
it is very stock appearing with stock covers tb and plenum , even rolling around on stock gn rims
and the stealth 67 turbo on TE compressor cover (looks like a te44) with the stock location stretch that looks stock (its a mease slic)
heads and intake by champion but they dont give away anything
, 218 roller with stock rockers so it used stock valvecovers so nothing to see there.. but those stock breeze clamps and IC hoses have to go
has a 3" thdp (mease) and it is girdled so if you looked underneath the car you might be tipped off that its not stock,
and i agree it should be around 530 at 21psi
went 97 in the 1/8 120 out the back last wednesday on 26" tires in the heat , without the help of a good launch
Yeah and the air in the shop sucked the last 2 weeks. You're going to go faster than 120mph out the back next time.actually i had it apart in many pieces replacing a piston but weber did build it first
Your sig shows that your non-stroker combos are comparable in the power department. What have you noticed about the stroker vs stock setup?
they cost a little more , but have more potential , personally i dont see the need for stroke unless plans are to full cage the car and get your nhra license
if 10s are the goal the std stroke can get it done but with the stroker youll get to tell your freinds you did it with less boost , still have to make the HP to run the numbers
the stroker will also let you run a tighter converter and a bigger cam and still have an acceptable idle and a streetable feel with the tighter connverter
the car bison mentioned needs a better converter than the AC9" and some taller tires and a real alky system as well as data logging
My diamond pistons are about 7 years old now, never had an issue with them. RPE built my shortblock. ran 30 psi at times to
.but i wouldnt recommend the diamond pistons
