- Nov 30, 2009
Those are some big shoes to fill , now it's your turn !!!Pollo Malo sold his car. So sad.
SignUp Now!Those are some big shoes to fill , now it's your turn !!!Pollo Malo sold his car. So sad.
I have a whole pile of parts headed out to Turbo Lou for assembly next Friday...........
It's been over a year in the gathering of everything.This engine is going to be a monster......
So friggin' excited!!!!!!
its just a dressing for engine bays not meant for internal parts or anything like that
a detailing product , keeps everything looking nice and clean
that's good he cuts it with water amorall is actually a horrible product IMOP, its petroleum based and once you start using it you have to keep using it, its greasy and attracts dirt and grim and will harm electronics and actually promotes cracking of plastics and rubber prematurely , it will also cause rubber to turn brown with extended use over long periods of time, 303 protectant is a much better product IMOPI had a friend years ago that turned me onto his engine bay detailing secret. Pressure wash the heavy dirt / grime off the engine then spray it down with a mixture which is 50 / 50 Armorall and water. Wipe the excess of the large surfaces and let the rest dry on its own. It's an expensive fix and works well.
Neal
Squirrel gathering nuts indeed ( emphasis on squirrel ) so let the saga begin after almost two years since guy finally wore out his previous build. I kept warning him that after 6 years of thrashing the engine needed to be torn down & freshened up. Guy has always spoken well of me & he will now get rewarded for his loyalty . I intend to give him every break possible to get him back on the road provided he has his evening cocktail after he posts & not start any pissing contests with anyone who happens to disagree with his enthusiasm. Mike Tomsinski owner of T/A has taken a personel interest also & his parts will be used exclusivly . His parts & service are well respected & top notch. I estimate finish time to be about three monts till Guy is back on the road & once again a menace to the streets of Phoenix & pest to turbobuick.com.
dyno results of last stroker motor build using stage II block 25 # boost pump gas alky injection. i thought i had a pretty good cold air inlet but note the difference in H.P. with air cleaner on then removed. So thats getting changed as well as a higher output alternator it wouldnt charge over 10 volts under boost. The dip in the graph because the trans wanted to down shift so operator wound it out in second then into third . I feel there is another 100 h.p. to be gained through tuneing & fixing the obvious.
on View attachment 339290
Guy...... glad to see you still addicted to these money pits,
this should be a really fun ride, keep us posted as I'm sure there are alot of
"kids" following this build.
oh, I had a similar build, and needed 3300 to 3500 stall converter to make it
stupid fast spooling,
